Engine code 121 & 542 | Ford Explorer Forums
LOCKONS7RA7US
Location
Everett , wa
Everett washington
1992 , eddie bauer
Callsign
Taco Run
So I hooked up my engr code reader and got some new ones
Code 121 o ( closed throttle voltage higher or lower than expected )
*how do I solve this problem ???
Code 542 c ( fuel pump secondary circuit fault )
** how do I solve this issue ???
Please help me this is my only car that I have for work .
121: replace the TPS (Throttle Position Sensor) yellow circle in the pic.
542: Replace Fuel pump relay. Under the power distribution block. IIRC it's the brown one.
disconnect the battery before replacing any electrical components.
I have already replaced the throttle position sensor twice .. new one on it.
Check your battery, alternator ouput voltage and cables.
A low voltage situation can cause the reference voltage to be to low and cause false fault codes.
How do I test the alternator output voltage
And what cables do I check ? Battery cables?
Use a volt meter. 14.2 - 14 .7 with the engine running.
Battery should read no less than 12.6 with the engine off. Best to have the battery load tested at the Auto parts store.
Yes, battery cables.
I think you can have the alternator load tested at the parts store too.
Another possibility is a bad connection or short in the wiring somewhere.
