BigBadWimp
- August 10, 2004
- Beaver Falls, PA
- '94 Sport
Hey guys, I was hoping you could help me out with these... I went to Advance Auto Parts to get my codes scanned and it came up with the ones below. The guy there said it could've started with the egr valve and all the other codes might just be related to that one. What do you guys think? Thanks in advance for any help you guys can give me.
KOEO Code 335
EGR PFE/DPFE Volts
Out Of Range
KOEO Code 539
A/C Or Defrost On
During Self-Test
Memory Code 172
HO2S (sensor)
System Lean
(Bank 1)
Memory Code 176
HO2S (sensor)
System Lean
(Bank 2)
Memory Code 181
No Definition
Available
Memory Code 186
No Definition
Available
Memory Code 189
No Definition
Available
Memory Code 211
Profile Ignition
Sensor
Circuit Malfunction
Memory Code 556
Fuel Pump
Primary Circuit
Circuit Malfunction
KOEO Code 335
EGR PFE/DPFE Volts
Out Of Range
KOEO Code 539
A/C Or Defrost On
During Self-Test
Memory Code 172
HO2S (sensor)
System Lean
(Bank 1)
Memory Code 176
HO2S (sensor)
System Lean
(Bank 2)
Memory Code 181
No Definition
Available
Memory Code 186
No Definition
Available
Memory Code 189
No Definition
Available
Memory Code 211
Profile Ignition
Sensor
Circuit Malfunction
Memory Code 556
Fuel Pump
Primary Circuit
Circuit Malfunction
