Hartman
- October 16, 2001
- Indianapolis, IN
I know a fair amount about the common problems on OHVs but I can't seem to narrow it down on my truck right now. I was on the highway coming home, about a 110 mile trip, and the CEL came on for about 20 minutes then go off. Also, the truck has a pretty noticable loss in power. I could barely make 70, and when I had the cruise set, the truck would slow all the way down to 62-63 going up a hill, then slowly return to normal speed after getting up the hill. Also, if I was maintaining 60 mph for example and I try to accelerate to 70, the pedal felt real stiff and if i stepped on it to get it going, the tranny would downshift and shoot up to 3-3500k rpms. Its almost has if something is straining the engine.
I've narrowed it down to a few things, but I can almost certainly elminate some of them.
1. Clogged cat - would explain the loss of power, but I would think that this would effect acceleration more.
2. 02 censors - Not sure why the CEL wouldn't stay on all the time if this was the problem.
3. I checked the PCV valve - seems fine.
4. It is possible that the power steering pump is going bad, but I'm not sure how to test it out. Might be starting to seize and straining the engine.
5. The DPFE sensor was recently replaced. Fuel filter has less than 20k.
Any body have any ideas here?
