wharriso
- August 25, 2006
- Philadelphia, PA
- 16 Explorer Limited
I took an 80 mile trip down the highway. Halfway to my destination I noticed a loud blowing sound as I stepped on the gas. It would come and go but I gave it no mind, I have heard that in the past, but it would only last for a few minutes. On my way home, about 30 miles away, the sound started up again. This time a glanced at the thermostat and noticed it was about 3/4 of the way up, its usually sitting about 1/2 way up. I turned off the air conditioner and turned up the heat so see if I could bring it down but that made things worse, the needle started hitting the red line, then it would drop down to 3/4. It did that the rest of the way home. When I got the car home, the engine was wet, there was smoke coming from somewhere, and there is a hissing sound coming from somewhere. I was able to pour about a half gallon of 50/50 mix in the radiator so I guess it overflowed during my trip. The radiator was replaced years ago so I guess my prime suspect is now the thermostat.
My question is, when this engine overheats, where is the overflow? The cap is dry. Does it sound like my engine is damaged?
