BootyDo
- April 21, 2007
- Baltimore, MD
- 2006 Limited V8
Hello,
I have a '99 Explorer that's just short of 100k and am starting to run into something. Specifically, the engine idles low and even stalls at times if I do certain things.
I'm not too sure how long ago, (probably since I got it 1 1/2 years ago), the engine idled rough. I've since had all the spark plugs and spark plug wires changed. When I thought things were getting worse, (it idles at 500), I bought a whole new Idle Air Control Valve. Nothing. I then picked up some of that Mass Air Flow cleaner and sprayed the heck out of it. After it reprogrammed, it idled around 900. But once it really got warmed up, it was back to the 500 rough idle.
Right now, if I tap the gas and immediately tap the brake, it'll stall. And when it's just moving on a drift, (like parking), it really sputters.
Should I just manually adjust my idle and, if so, where is that?
Thanks!
Thanks!
