ENGINE PROBLEMS???????? | Ford Explorer Forums
makaveli911
edmonds, wa
explorer 94 sport
i don't really know if this is a problem or not but the cicular thing on the right top (all the circular things are connected to the fan belt) rotates on and off. When it rotates the RPM's goes up and shakes the car when stoped. It also makes a clicking noise. I am not to familiar with car engines got any suggestions?
watch out it sounds like your motor is about to explode!!
J/K no it's only your ac and it doesn't sound like it's a problem
Clint, you scared me for a second lol but really my ac does not work so should i get that checked out?
Yup, that's your A/C compressor cycling on and off. Totally normal. However, you said your A/C doesn't work. Sounds like you're low on freon. Does your compressor kick on and then stop pretty quickly? That's called "short-cycling" and means you're low on freon.
peace
Mike
