iLoveMyExploder
- October 11, 2015
- Texas
- 1993 Explorer XLT 4X4
ive read many forums here about similar problems like this, but none are the same as these symptoms- so here goes...
ok so my exploder is not a daily driver and has been parked for quite awhile since the transmission started leaking.... I got no major money to fool with it- since my last heart attack I have been out of work dealing with a super slow recovery. but I still go out and start it up periodically just to let it run at idle.
so someone suggested I put a bottle of this blue devil transmission sealer in it to try and stop the leak. directions on the bottle said to drive it after adding it to the fluid. ...a couple months ago I put fluid in it and drove it around the block- and when I returned, it had not lost major amount of fluid, I figured it would be fine to do that again after adding the blue devil.
but this time, when I went "around the block" (2-3 miles) it was doing fine all around until suddenly- the engine started losing power and running around 500 rpm after maybe a mile or mile and a half. no shuddering, shaking, sputtering- no check engine light-- nothing unusual- just suddenly had no get up and go- as if it had just ran out of gas, but did not die. but the fuel gauge said it has 1/4 tank.
I stopped the truck and raised the hood, with it still running (at low rpm at idle). was running nice and smooth. then I thought it would be best to shut it off and check the fluids. everything seemed to be in acceptable ranges, except could have used more water in the radiator and was almost a quart low on oil- (needs a change)- but I don't believe these things would contribute to a loss of power.
so I sat there a few minutes, started it up again- and went further down the road- closer to the house. it revved up and shifted and acted normal again- then maybe 2/10-3/10 mile later- it did it again. so- I repeated the shutting it off and letting it sit, then moving further down the road- did this a total of 3 times. the 4th time starting it up and going, it maintained power and acted normal all the rest of the way home (less than 1/8 mile), but I didn't attempt to do the speed limit- I didn't go any faster than 20 or 30 MPH.
another thing to compare it to- think of an old 80's car with the distributer loose, mash the gas- it will go, but when you slow down and them accelerate again- no get up and go. that's how it was acting, except it just suddenly lost power without slowing down first
when I got it back to the house- the trans fluid was low again. so I suppose the blue devil didn't work, and the leaky gasket is too big for additives to handle.....
any ideas why the engine lost its get-up-and-go like that, but got it back temporarily after a couple minutes rest? ive never experienced these symptoms like this before, except in a 85 crown vic with a loose distributor as the culprit...
no shuddering, shaking, sputtering- no check engine light-- nothing unusual- just suddenly had no get up and go, and continues running smooth, but just at 500 rpms or less.
maybe the fuel pump is no longer putting out enough pressure anymore? maybe it really was out of gas and running on fumes, and the fuel float is stuck? this is supposed to be a common problem with explorers, maybe that's it? ...any ideas?
