Engine Swap 92 Navajo | Ford Explorer Forums
KIMO4
NORRISTOWN, PA.
1992 MAZDA NAVAJO
:navajo:Has anyone considered the new Eco boost engine from Ford?
Is it possible?:thumbsup::thumbdwn:
where would you get one of those?
Sure it is possible. You just need the ECU, wiring harness, custom engine mounts/exhaust, instrument cluster, antitheft devices, lots of money, lots of time and a good divorce lawyer for when your significant other leaves you.
If you can't afford a brand new truck and you don't have a pretty well equipped shop as well as a good deal of fabrication/mechanical skills and a good amount of skill with electronics, I would not suggest this project... it is not gonna be a weekend thing.
An easier swap would be to a diesel engine like a 4bt cummins, b3.3 cummins, isuzu 4bd1, older ranger diesel (the small underpowered one) or a mercedes om617. There are a couple of gas engines you could swap in as well that with the proper tuning can give you reasonable fuel mileage while still giving you a good bit of power. A 302 can be tuned to give you above 20 mpg, and I hear that Trucks on Spike TV swapped a 4.6 DOHC out of a Lincoln continental into a ranger (though they later went to a Cobra's DOHC 4.6). My old continental could get up to and over 30 mpg cruising and had a TON of power if you pressed the noise pedal. I should note though that any of these swaps will likely cost you more than your truck is worth, so, save up your pennies.
The engine is a curiosity of mine. It seems as though Ford has done the research and testing. The idea of having a power plant of that caliber in a total Navajo restore is off the hook. Just dreaming,
Check out the stress tests on Youtube, it's crazy how much abuse that thign can take.
We've tossed the idea around of tossing it into my Explorer, thing would def haul some ass. But I'm more partial to a stroked out 302 simply for saying... "I have a stroked out 302".
Definitely a cool engine though.
