n0xdw
- September 4, 2006
- Akron Co
- 85 Bronco II
Nice project, well done, almost done like mine.
Do you have to run the PCM inside? Is there room under the steering column for the PCM to be mounted on the firewall, like the Crown Vics?
Do you know how much extra length you need? Spare wiring harnesses are very handy for splicing in new/extra wires with matching colors. Good luck,
Thanks for the comments.
I guess i am not certain how the Crown Vic is set up, but i thought i would mount it where the original one did. It is the same size PCM just more connections. I am guessing about 3 1/2 feet longer will get it right there. Far as splicing on another harness, that is real difficult for me as i am partially color blind so matching up colors can be a significant challenge.
Comparing voltages on Pin 5 of the Cruise servo module with a 97 P/U they were reasonably comparable across the board i thought. I will probably see if i can find another servo.
