Cory Conner
- March 26, 2019
- CA
- 1994 Ford Explorer
I'm new to this forum and the explorer world but I appreciate all the help in advanced! So recently I purchased a 94 4.0 explorer 4x4 with 330k on it, the price was right at $800 and I was looking for a fun 4x4 for the family. It had a check engine light on but I had never scanned an obd1 before so I believed the guy when he told me it was only the mass air flow sensor. After using a jumper wire and getting the codes flashes back at me it also gave me a 332 and a 558. I replaced the intake manifold gaskets, it was clear they needed replacing. The CEL went off after replacing the gaskets, interesting. I drove it like that for a couple days with no issues. Battery died on me so I bought a new one and noticed the vapor purge valve vacuum lines had cracks in them so I replaced the vacuum lines and the purge valve itself. Then I started it and the CEL was back, weird. Now a new problem surfaced. It would take between 30 seconds and 5 minutes for the CEL to illuminate after startup, during that time it ran great with no issues. As soon as the CEL comes on an engine tap begins, as far as I can tell it sounds like lifters but I’m no mechanic. It also has trouble staying running while idling, often the RPMs drop for a second then it catches itself. Does anyone have any idea where I should start to diagnose or is the answer ‘You bought a high mileage car that starting to give up.” Sorry for the long post but I’m trying to give as much information as I can.
