Engine Temp | Ford Explorer Forums
Engine Temp
Cheford
Hey
My 97 Explorer XL's Engine Temp guage doesn't work (The top Left guage) It moves but not past "C", i'm thinking its the Engine Coolant Temperature Sensor. Am i correct in thinking this or is there some other issue?
How's the heater output? If it's good'n hot then it's the sending unit over by the t-stat housing (on the 4.0 OHV).
If the heater is cold/cool after it's been running for 15-20 minutes then it's more than likely the thermostat.
Hey
You mean the gauge temperature sender, yes very likely. It has one wire. I would also replace the thermostat too if you have the OHV engine. Be sure to get one with a bleed hole or the motorcraft one.
