TestPoint
- August 21, 2009
- Ellijay
- '00 5.0 in an '82 Volvo
I am in the process of installing a 5.0L '00 Mountaineer engine/transmission in an old Volvo.
Found a 10k mile engine/trans in a wreaking yard warehouse from the same vehicle, one of the infamous Firestone rollovers. When assembling everything lines up, flex plate holes to converter bolts, pins in engine to trans holes, converter hub to crankshaft and bolts together.
Tried to turn engine when assembled. Locked up tight. Loosened bolts and engine turns. Disassembled, pulled converter. It appears to fit fine on its shaft and pump and turns freely.
Reassembled. Engine turns until I close the last 1/8" of the lower bolts and then locks the engine. Neither flex plate nor steel plate behind appear to be bent. I cannot see anything interfering nor any marks on any parts. I did clean converter hub and crankshaft socket and lightly oil.
Any thoughts would be appreciated. Probably won't be the last time I am here asking for help.
