DaveFuk
- July 8, 2006
- Lancashire UK
- 99 LPG convert stock 4ltr
Hi All
My X has started to use water, and i cant tell if its a leak externally or something like the head gasket, can we shed some light on it.
The symptom are as follows.
When engine is cold the radiator is full and no air present (heater turned on)
Start the engine and run, nearly to temp and then the radiator blows water into the expansion bottle.
once up to normal temperature there is no overheating
no steam from exhaust
no change in water levels etc until you stop again then it does it again?
I can do Lancashire to Cornwall (400 miles) no change in water level after the first dump of water.
Any ideas Boys and Girls
