stkelly
- October 28, 2007
- Laytonsville, MD
- '08 Mountaineer
After a shop had to rebuild the heads and timing area on my engine due to a bad repair job (see link below if you'd like to read more) it seems I'm using quite a bit of oil. My engine seems to be using about 1.5 quart of oil within ~4500 miles. Before the rebuild I used no oil between 5K mile oil changes. The truck has about 83K miles.
I've already taken it back to the shop and they keep saying nothing is wrong.. Of course nothing is wrong to them!
There are no obvious leaks. Any suggestions as to what to look for when trying to find what's causing the oil use? It seems I can perform a pressure test and that should tell me if the piston rings are ok. But how can I test the rebuilt heads? Also, is there a chance that this much oil use could be due to breaking in the heads?
Thanks in advance!
Link to thread about shop damage:
http://www.explorerforum.com/forums/showthread.php?t=390513
Thanks in advance!
