JME5150
- November 9, 2006
- Saratoga Springs NY
- 2004 XLS
Hey All,
I am hoping someone can point me in the right direction. I have 2004 V6 4.0 L
When the explorer is at idle, there is a slight vibration thru the vehicle. The engine all the way to the tail pipe is vibrating. The vibrations get worse when the compressor is running...(a/c or defroster).There is no check engine light, I don't know if it is a rough idle because the engine does sound smooth and there is no fluctuation on the tach.
I did change the plugs but not the plug wires, I changed the fuel filter, had the injectors cleaned, cleaned the MAF and the throttle body and changed the air filter. i have not done anything to egr valve, and I dont think this year explorer has an IAC. I also put in STP gas treatment and injector cleaner. Nothing so far seems to work. Am I dealing with a vacume leak or maybe a broken motor mount? I would really appreciate some input and opinions.
Thanks in advance
JME5150
Thanks in advance
JME5150
