iand86
- November 8, 2010
- kelowna bc
- 92 xlt
So i got 93 ford explorer 4.0l, when i start the engine cold it will rev up to about 2500 rpm but wont go past. if i step on it then engine seems like it wants to go but it wont, it wont go past 2500 rpm. as the motor warms up it gets worse, ill be lucky to hit 1500 rpm. ive replaced the MAF and TPS sensor and air filter, to no avail. BUT when its warm and running like crap....if i pull over turn the engine off, pull off the maf and tps sensor, start the truck and let it run for 10-20 seconds or till when it dies, turn off the key, plug the MAF and TPS back in it will run better (better as in up to 2500 rpm still) for 2-3 minutes. if i run it for a while at 1500 rpm going up a hill the engine will begin to stutter and a check engine light will come on...then turn off (engine light) once its not underload. what in the hell is going on! i dont think its mechanical...sounds like a sensor...but which one??
Oh ya, replaced wires and plugs less then a year ago.
