mikeinpa
- January 16, 2003
- Clifton Heights, PA
- 91 Explorer XLT 2WD
Ok, so Im on my third fuel pump relay. Sometimes when shutting the engine off it works as it should, sometimes it "hangs" for a few seconds (1-15 sec.), but lately with the cold weather Ive had to resort to opening the hood and giving it a whack bafore it will disengage. All wiring seems intact (at least what I can see).
Im getting very tired of this and was considering installing a switch to cut the power to the relay from inside the truck, almost like a kill switch or anti-theft switch. Does anyone have any comments regarding this mod? Is this a bad idea? Is it inspection legal in PA? Also, If you happen to know which wire I need to install the switch in it would be a great help.
Thanks in advance...this forun is great!
