Evap line diameter needed. | Ford Explorer Forums
Mike65
Location
In my garage working on one of our vehicles.
Horsepasture, Virginia.
2005 2WD Regular Cab F150
On my wife's 99 Explorer Sport it has the CEL on & the code is PO455, large evap leak. Well this is the same code I got last year when I fixed the leak in the metal line that ran over the top of the gas tank that came from the charcoal canisters that had rotted out. I had replaced it with a length of fuel injection hose & eliminated the badly rusted section of metal line. The CEL came on during the winter & now that it is getting warmer I crawled under the truck & found the other metal evap line that runs to the front looks badly rusted & I want to remove the rusted section & replace it with more of the fuel injection hose like I did with the other one. I need to know what the diameter of the metal evap line that runs to the front of the truck so I could get the hose & have it on hand before I cut the metal line. So if anyone knows the diameter of the line please let me know. IIRC when I replaced the evap charcoal canister bracket I also replaced the valve that is mounted on the canister.
Bump.
For what it's worth, I just measured mine (97 Sport) with a caliper and the metal line OD is 5/8" .
Edit : make that 1/2"
Thanks Pete, that is a big help.
I just measured the evap line going from the purge(?) valve to the throttle body.
It was 5/16" ID. That seems about right considering 007's metal line that's 1/2" OD.
