shifty1
- November 10, 2003
- orangeville, ontario
- '94 XLT
Hello all, I need help!! My truck needs help too!!
I have asked this question before, but the problem is getting much worse. Here is whats happening.
The truck will stall without any warning whatsoever. It doesn't matter whether during accelleration or decelleration.
For the last 7 months it would happen once or twice then go a few weeks to a month or so without happening again. As of this weekend it was happening every 30 sec to 5 minutes.
There is no sputter or surge, I'll just be driving, look down at the guages and see 0 rpm, then the CEL and battery light come on and bye bye power steering. (I'm not showing any codes).
I can sometimes put it in neutral, turn off the key and get it to start before coming to a stop.
Most of the time, it will come to a stop, I put it in park and it will take from 1-5 minutes for it to start up again.
Last week it was turning over, but would not start at all, put it in the garage and they found a (supposedly anyways) bad wire at the PCM Relay. After changing that, it was fine for a week (as I said before it is not uncommon for it to go a week or more between occurances).
This weekend my pregnant wife and I were headed out of town and it started again, only very frequently this time.
One thing I did notice and I'm not sure if it means anything, but it has never stalled when I'm on Cruise Control?? It stalled twice in a 1/2 km (canada) stretch, got it going on the hwy rode the cruise and didn't stall the rest of the way home (250km's).
I have previously switched the fuel relay w/ another, cleaned MAF and IAC, changed plugs and Fuel Filter.
I do not think that this is a fuel problem due to the intermittentness (new word), and there is no sputtering.
Any chance that this would be an ignition component (would this not happen if spark was lost?) What would be the best way for a driveway wannabee mechanic to test for a problem here, or is it possible?
PCM?? If the mechanic found a fault w/ the power to the PCM relay, could it have actually been the power in the PCM that was failing??
I am leaning towards the computer, but it would be a pretty expensive mistake.
Maybe a bad ground somewhere?
BTW, my stereo and lights whatnot DO NOT fail so it doesnt make me think that I am losing "power". Just the engine.
Sorry about the long post, its just that I want to get everything figured out, especially considering my 8 month pregnant wife drives my truck now more often than not (at least until this weekend she did).
