Exhaust Studs vs. Bolts | Ford Explorer Forums
warrenoliver
Madison Wisconsin
1996 Ford Explorer 5.0L
I just removed my exhaust manifold from my 96 Explorer with 5.0L engine. I got all 6 bolts out and both studs. I have ordered a replacement Dorman manifold.
My questions are: Why the studs and bolts? Am I OK to replace all of the studs and bolts with new grade 8 bolts only? The Dorman exhaust shows it comes with the manifold gasket and two bolts - are these the bolts that go in the exhaust pipe connection?
Thanks for your help.
are you talking about the down pipe? like that connects the manifold to the rest of the exhaust? i thought that had bolts and nuts behind it from the factory? if so your new kit should have came with 2 nuts as well
ill look under my truck after work and get a better answer though and if that is the case i think there is 2 for each side.
