Exhaust tip install | Ford Explorer Forums - Serious Explorations
Exhaust tip install
aldive
Elite In Memoriam
1999 XLT
I finally got tires of looking at my round 2 ½ inch pipe exiting under the rear bumper and decided to install a stainless steel “exhaust “tip”.
I chose to use a 2 ½ inch inlet x 3 inch angled cut exit tip for the installation.
I tool my Sawsall and cut off 5 inches of the exhaust pipe, slid the new tip in place, and welded it on.
I think it looks better than the plain round pipe that was previously there.
that looks real nice..very clean
Great Mod Al. Might look a little better if it was closer to the bumper tho, just my opinion
Looks nice. How about a picture from farther away though?
looks good!
I think the smoothness of the SS will add 0.05 mpg over the stock pipe!
:thumbsup:
Your wish is my command .....
Looks good! Did it give you any horsepower??
just kidding.
I like the lights under your bumper.. are they wired independantly with a switch? or do they tie into the reverse lights?
The lights illuminate only when the truck is in reverse; no separate switch.
Nice looking. I'm inspired. How long is the tip and what was the cost?
Looks good. Looks very similar to mine, it might even be the same tip. The only thing different is that min was routed to the side by the muffler shop that did my cat-back.
A few more pics .......
aldive
i dont have an angled tip, but where can i get one, and how much do they cost
Explorer96xlt said:
aldive
Try Summit Racings and Jeg's.
Good luck .......
If the first pic, your reflection looks like you are wearing aligator cowboy boots
Whats a well dressed redneck 'posed to wear?
That is some pretty decent welding. Good stuff!
-Drew
-Drew
I'm a certified welder (job) and it does look nice IMO. It's easy if you take your time. Almost all mufflers shops always do shotty work because they rush on everything.
BeauJ said:
I'm a certified welder (job) and it does look nice IMO. It's easy if you take your time. Mufflers shops always do shotty work because they rush on everything.
Beau, chains such as Mienike may do shoddy work, in and out agreed.
My guy runs the best beads in the biz, no slag, paints all his welds with aluminized paint when done, invites you to look at the work before it comes off the rack, your comment that all muffler shops do shoddy work is not true, some do take alot of pride in the work they do
You're right. I forgot to put "almost" in front of it, but it's fixed
That is sweet looking i need a new tip i bought one from auto zone that had a slashed tip for 6 bucks i was an idiot and just used the screwws and did not have it welded on. GRRRR it fell of doing about 70 on the highway, the next one ill bolt into the existing pipe or just have somebody weld it.
