Let's clear a few things up
I'm trying to go on a "posting diet", and you people keep pulling me in
. I think we need to clear up some misconceptions. I need a woman to tell me that I talk way too much on topics I'm stupid about, but since she's not around, here goes.
Ignore at your leisure.
"Posi-traction" is merely a trademark term for "limited slip"; we're just talking semantics here. A "locker" is always going to be called a "locker".
Posi, limited slip differential(LSD), whatever the name; they are relative applications of the same differential engagement type, and both will spin the same way if you jack the rear up and spin one wheel. They are clutch activated and use clutch plate pressure force to transfer power to both tires, though they may differ in amount of positive engagement according to different circumstances.
A locker of any kind will
lock the two sides and create a solid axle during times of positive engagement. They will not slip. This is not the same as either posi or LSD.
With a stock Trac-Loc LSD in your 4wd Explorer you can do things that will shock you. A locker will up the ante, giving you the ability to tackle trails that threaten body damage. It all depends on how far you are interested in taking this hobby. I must interject here that capable tires make a huge difference once you get to this level of activity and are as important as the rest of your setup.
SO:
swak6287, the bigger tires are fine. I've seen Ray in action and you certainly won't have any problems.
JonM, you got it; posi and LSD are similar and clutch driven, lockers are
locked. However, most have release mechanizisms for operation on hard surface so you won't break an axle when you turn a corner on the street.
Goober, posi and lockers are not the same. Posi is LSD, lockers are lockers.
Donkey Boy, to answer your original question; like I said, I've seen Ray in action. He's done some really fun things with the same gearing/tire setup you are asking about. Your vehicle is capable of duplicating Ray's feats. None of us can say whether the offroading contributed to his tranny problems or not. At his mileage, CA traffic could have done the same thing. If you want to play and try this sport out, I say go for it. I know I'm having a great time.
Hope I didn't offend anyone, and helped someone!
[Edited by GJarrett on 07-19-2000 at 05:51 AM]
