Explorer 2010 AC vent in cabin not blowing | Ford Explorer Forums
Sambosat
Khobar
2010, explorer 4l
Good Day to ya all. My 2010 explorer 4.0L started to have heating issue 2 years and when I took it to mechanic he advised to remove the heating system as I'm living in a very hot environment that requires only AC. Ever since I'm using the car without the heating system. About a year ago, the AC started blowing air from defrost only when I start the car, then 2-3 mins after, it would blow the air from the passenger and driver side. i was told that this was an issue with the blend door actuator so I went ahead and replaced the blend door actuator. That did not fix the issue and the issue remained the same. Now since two weeks (when weather started to get warmer and warmer) my Children started complaining about AC not working in the back seat (you know, the one on top in the roof). I have tested the fuses but I was not able to find any defective fuse and now I'm out of ideas. Not sure what is the cause for the problem so I can get it fixed. I took it to several repair shops and they all said it is electrical issue and they do not know how to fix. I took it to the dealer and the dealer said that they will have to charge me 150$ for checking it. So anyone can share any lead so I can try to fix it. Thank you in advance for this great forum
This might be your problem...
Thanks for the reply. I will check it out and confirm
