Explorer DIY gun/valueables lock box mounting! | Ford Explorer Forums
polizi212
Northeast Ohio.
2008 Ford Explorer XLT
I love my Explorer and it has been a good Vehicle so far but it lacks any kind of storage area where I would feel comfortable keeping my Firearm securely locked up in. Glove box is not secure the center console is not lockable nor would it take much to rip it open.
Well since I am licensed to carry a concealed firearm, I needed a place to lock my Firearm up when I am unable to take it into a location that forbids them. Yes I try to avoid that but sometimes you just have to do what you have to do! Looking at the market of available options some too cheap and flimsy and others so expensive you might need a loan to buy them. I decided on a locking gun box made by Bulldog
After getting this and seeing its construction its a sturdy item that will keep lowlifes from just walking away with your goods!
This car vault has two main parts! The shell/sleeve that mounts to the vehicle or other objects!
And the Actual lock box its self.
these two mate together by sliding the lock box into the sleeve and then locking the two together with the lock on the box.
The box I bought was the large version and as you can see its plenty big enough for my Ruger P95.
The next issue I had was where in the heck was I going to mount this and be able to access it easily. I looked under my front seats but neither the passenger side or drivers side had any room to mount this with out removing wires and I was not going to do that. I also have a dislike for just drilling holes in perfectly good cars if I don't need to. So I had to hunt around for a good mounting point! My search lead me to the space under the 2nd row seat on the Passenger side that had a really nice area for my vault that also had a slight elevation to it and had a good metal point to mount my box to. In this picture You can see I already have the hole tapped. But if you look at this area on a 2008 Explorer you will see it has two hole already in the metal cross piece, so I didn't have to drill I just tapped the hole to fit the bolts I was going to use. The area is also just slightly off the center of the vehicle so I can reach behind my seat and access the box from a seated position.
So here is what I did! You may do something different! I didnt take picture of the actual work as I was doing it. I did these after i was done.
First I found the location I was going to mount my box and then I figured out the hole size and made a trip to Lowes for bolts I found some 5/16 18 thread Allen head bolts about 1 inch in length. These are used to bolt the box to the floor.
Next I needed to mount the mounting sleeve to some plywood so that that could be secured to the floor. I made the plywood a few inches longer to allow for the mounting bolts and it also put the vault in just the right space.
The plywood I used was 1/2 inch. I attached the mounting sleeve to the plywood and then attached it to the floor in the hols I tapped earlier.
In order to save my fingers I used my electric drill with a modified Allen key to quickly run the screws in nice and snug!
After it was all tight you can see it is out of the way and you really have to be looking for it to find it under the seat. The way it is mounted the seat has a cross bar that runs just over the top of the vault keeping you from pulling up on the safe to pry it out and since it rest on the center hump you can not push down on it to break it free either, It is not 100% going to keep a bad guy from taking my stuff but I do not think in the short time he will have a chance that he is going to be able or willing to try to get it open.
Here is a shot of the inner box half out of its mounting sleeve!
For good measure the box has a cable that you can use to further secure your items to you car!
The project didnt cost much and here is a break down of what it cost me. Your cost could be different!
Bulldog Gun Vault $41.08 From Amazon.
Allen Head Screw $ 1.15
Plywood -Free
Time for this project about 1 hour and 15 mins mostly finding my tools and shop light and then cleaning up. I really like my lock box location and After I made some modifications to the interior lining of the box its much better now.
Why not take that piece of plywood down to a welder or a metal shop to use as a template and have someone cut you a piece of 1/8" or something like that?
Just... My thoughts on plywood... seems like it wouldn't be too hard to rip that safe out of there with a tire iron or something.
Your Idea is already in the works sorry I should have included that but at 1 am I was a little sleepy. A side from welding a safe to the floor nothing is ever going to be totally 100% secure. I am more worried about the smash and grab guy not someone who is going to take 10 to 15 minutes trying to get something he has to look hard for and work even harder to get.
Nice Job, way better than just mounting it behind the 3rd row seats. Also, good choice on the use of OSB instead of metal. The metal would add vibrations to the floor/cabin, but the wood is good at absorbing the vibratons.
The is a good idea, i will have to go something like this soon, even if not for a handgun this would be great just for anything somewhat small you dont want stolen.
The box is pretty strong and I think a pretty good idea for anyone who has to store important items in their car. Whether that's a gun, jewelery, a IPod or what ever. My intent here was to show you a good option to secure your items! Yes you could add more steel or weld it in place or use some fancy hi-tech anti theft bolts, Its up to you and your imagination, skill and or wallet. I hope someone can use what I did and protect their stuff!
That's a pretty darn cool idea. Nicely done!
Great idea...1 question, did you use the standard size Bulldog box or the large???
Dummy me...I reread the post...You used the large box...:thumbsup::thumbsup:
Thanks 4df150, I went with the large box because I wanted to be able to put more than 1 item in there. I also went ahead and bought some foam sheets and glued them in a stack and cut out the outline of my firearm so that when its in the box it will be less likely to slide around. I cut the foam so it fits tight in the box but I didnt glue it down so I can take it out and store other items anytime I want!
I thank this will be my next project for the EB. Two years ago on vacation in Arizona the Ex was broken into, broke drivers side window. Lost the GPS, radar detector and some other odds & ends. Luckily I had my gun in the room with me.
I think for a little piece of mind this is a good solution. I got my box on Amazon no one had it locally, the foam for the inside I was able to get at my local hobby lobby and as a bonus it is acid free so I don't have to fear the foam causing issues with my stuff I think I paid like 1.50 a sheet for the foam it comes in like 20 colors. The only issue right now that I can find is that I could use a light under my rear seat to see the mounting shell when I am putting this back in from the drivers seat.
