Education on O2 sensors and Air-fuel ratio meters (Poor mileage may= Bad O2 Sensors)
I believe the O2 sensors in my 1994 Truck only register On or Off (narrowband).
Are you referring to the O2 sensors or the A/F Ratio Gauge?
Is there any benefit in modifying to a wideband Air/Fuel gauge for a 1st gen Explorer?
Will the ECU even be compatible with a wideband O2 sensors output?
Info from Wikipedia:
Wikipedia.com (O2 sensors)
Information on oxygen concentration is sent to the engine management computer or ECU, which adjusts the mixture to give the engine the best possible fuel economy and lowest possible exhaust emissions. Failure of these sensors, either through normal aging, the use of leaded fuels, or fuel contamination with silicones or silicates, for example, can lead to damage of an automobile's catalytic converter and expensive repairs.
Tampering with or modifying the signal that the oxygen sensor sends to the engine computer can be detrimental to emissions control and can even damage the engine. When the engine is under low-load conditions (such as when accelerating very gently, or maintaining a constant speed), it is operating in 'closed-loop mode'. This refers to a feedback loop between the fuel injectors and the oxygen sensor, to maintain stoichiometric ratio. If modifications cause the mixture to run lean, there will be a slight increase in fuel economy, but a possible increase in nitrogen oxide emissions (dependent on excess air and high combustion temperatures although leaner mixtures have lower peak temperatures due to a slower burn), possible misfiring (at ultra-lean mixtures), and slightly higher exhaust gas temperatures. If modifications cause the mixture to run rich, then there will be a slight increase in power, again at the risk of overheating and igniting the catalytic converter, while decreasing fuel economy and increasing hydrocarbon emissions.
When an internal combustion engine is under high load (such as when using wide open throttle), the output of the oxygen sensor is ignored, and the engine automatically enriches the mixture to protect the engine. Any changes in the sensor output will be ignored in this state, as are changes from the air flow meter, which might otherwise lower engine performance due to the mixture being too rich or too lean, and increase the risk of engine damage due to detonation if the mixture is too lean.
Sensor surveillance
The air-fuel ratio and naturally, the status of the sensor, can be monitored by means of using an air-fuel ratio meter that displays the output voltage of the sensor.
Sensor failures
Normally, the lifetime of an unheated sensor is about 30,000 to 50,000 miles. Heated sensor lifetime is typically 100,000 miles. Failure of an unheated sensor is usually caused by the buildup of soot on the ceramic element, which lengthens its response time and may cause total loss of ability to sense oxygen. For heated sensors, normal deposits are burned off during operation and failure occurs due to catalyst depletion, similar to the reason a battery stops producing current. The probe then tends to report lean mixture, the ECU enriches the mixture, the exhaust gets rich with carbon monoxide and hydrocarbons, and the mileage worsens.
From Wikipedia, the free encyclopedia
An air-fuel ratio meter monitors the air-fuel ratio of an internal combustion engine. Also called air-fuel ratio gauge, air-fuel meter, or air-fuel gauge. It reads the voltage output of an oxygen sensor, sometimes also called lambda sensor, whether it be from a narrow band or wide band oxygen sensor.
The original narrow band oxygen sensors became factory installed standard in the late 70's and early 80's. In recent years, a newer and much more accurate 'wide band' sensor, though more expensive, have become available.
Most stand-alone narrow band meters have 10 LEDs and some have more. Also common, narrow band meters in round housings with the standard mounting 2 1/16" and 2 5/8" diameters, as other types of car 'gauges'. These usually have 10 or 20 LEDs. Analogue 'needle' style gauges are also available.
As stated above, there are wide band meters that stand alone or are mounted in housings. Nearly all of these show the air-fuel ratio on a numeric display, since the wide band sensors provide a much more accurate reading. And since they use more accurate electronics, these meters are more expensive.
Benefits of air-fuel ratio metering
Determining the condition of the oxygen sensor: A malfunctioning oxygen sensor will result in air-fuel ratios which respond more slowly to changing engine conditions. A damaged or defective sensor may lead to increased fuel consumption and increased pollutant emissions as well as decreased power, and throttle response.
Reducing emissions: Keeping the air-fuel mixture near the stoichometric ratio of 14.7:1 (for gasoline engines) allows the catalytic converter to operate at maximum efficiency.
Fuel economy: An air-fuel mixture leaner than the stoichometric ratio will result in near optimum fuel mileage, costing less per mile traveled and producing the least amount of CO2 emissions. However, from the factory, cars are designed to operate at the stoichometric ratio (rather than as lean as possible while remaining driveable) in order to maximize the efficiency and life of the catalytic converter. While it may be possible to run smoothly at mixtures leaner than the stoichimetric ratio, manufacturers must focus on emissions and especially catalytic converter life (which must now be 100,000 miles on new vehicles) {fact} as a higher priority due to U.S. EPA regulations.
Engine performance: Carefully mapping out air-fuel ratios throughout the range of rpm and manifold pressure will maximize power output in addition to reducing the risk of detonation.
Lean mixtures improve the fuel economy but also cause sharp rises in the amount of nitrogen oxides (NOX). If the mixture becomes too lean, the engine may fail to ignite, causing misfire and a large increase in unburned hydrocarbon (HC) emissions. Lean mixtures burn hotter and may cause rough idle, hard starting and stalling, and can even damage the catalytic converter, or burn valves in the engine. The risk of spark knock/engine knocking (detonation) is also increased when the engine is under load.
Mixtures that are richer than stoichometric allow for greater peak engine power when using gaseous fuels, due to the cooling effect of the evaporating fuel. This increases the intake oxygen density, allowing for more fuel to be combusted and more power developed. The ideal mixture in this type of operation depends on the individual engine. For example, engines using forms of forced induction such as turbochargers and superchargers typically require a richer mixture under wide open throttle than naturally aspirated engines.
Cold engines also typically require more fuel and a richer mixture when first started, because fuel does not vaporize as well when cold and therefore requires more fuel to properly "saturate" the air. Rich mixtures also burn slower and decrease the risk of spark knock/engine knocking (detonation) when the engine is under load. However, rich mixtures sharply increase carbon monoxide (CO) emissions.
Oxygen sensor types
Oxygen sensors are installed in the exhaust system of the vehicle, attached to the engine's exhaust manifold, the sensor measures the ratio of the air-fuel mixture.
As mentioned above, there are two types of sensors available; narrow band and wide band. Narrow band sensors were the first to be introduced. The wide band sensor was introduced much later.
A narrow band sensor has a non-linear output, and switches between the thresholds of lean (ca 100-200 mV) and rich (ca 650-800 mV) areas very steeply.
Also, narrow band sensors are temperature-dependent. If the exhaust gases become warmer, the output voltage in the lean area will rise, and in the rich area it will be lowered. Consequently, a sensor, without pre-heating has a lower lean-output and a higher rich-output, possibly even exceeding 1 Volt. The influence of temperature to voltage is smaller in the lean mode than in the rich mode.
A "cold" engine makes the sensor switch the output voltage between ca 100 and 850/900 mV and after a while the sensor may output a switch voltage between ca 200 and 700/750mV, for turbocharged cars even less.
The Engine Control Unit (ECU) tries to maintain a stoichiometric balance, wherein the air-fuel mixture is approximately 14.7 times the mass of air to fuel for gasoline. This ratio is selected in order to maintain a neutral engine performance (lower fuel consumption yet decent engine power and minimal pollution).
The average level of the sensor is defined as 450 mV. Since narrow band sensors cannot output a fixed voltage level between the lean and the rich areas, the ECU tries to control the engine by controlling the mixture between lean and rich in such a sufficiently fast manner, that the average level becomes ca 450 mV.
A wide band sensor, on the other hand, has a very linear output, 0 - 5 V, and is not temperature dependent.
Which type of air-fuel ratio meter to be used
If the purpose of the air-fuel ratio meter is to diagnose an existing or possible problem with the sensor and/or to check the general mixture and performance, a narrow band air-fuel ratio meter is sufficient.
In high-performance tuning applications the wide-band system is desirable.
OK that was alot of typing! :Yuenglingchug:
