explorer...stalling? | Ford Explorer Forums
Rcman098
Port st. Lucie florida
1999 Eddie Bauer 4x4
Ok so after owning this fine machine for about 2 years I have noticed an unusual problem....
About a year after I got the truck I noticed that when I started the truck in the morning, usually under 60 out side, it would start no problem at all untill this started.... Turn the key, fired up and the rpms would jump to around 2k and then start to come back down like normal and then just stall out. It fires up again but it takes about a second to get going then it runs no problem! More recently however it stalls like this at any ambient temp. Once I drive it and the go to start it again the problem doesnt occur. Once I re start the engine after it stalls there are no issues what so ever....I have no idea whats causing this.
SIDENOTE: When I hold the throttle at around 1000 rpm or just under and let off, the truck either dies or almost dies. This happens at any engine or outside temp
at one point in the throttle I notice that the more gas I give it does not make it accelerate any faster. From about 50mph up, the more I push down does not accelerate any faster untill I have the pedal all the way down, then it takes off.
thanks for any advice!
