I know Ted is on his way, so to achieve 295lbs torque both of you should probably stand on a breaker bar to tighten that on. That should probably to the trick. That's how I tighten my outer hub nuts to "spec"
All done, got to dark for pics But the FX4 coilovers did raise the nose about a 1 1/2 of so
Thanks to Tbars for stoping bye to check my 220, which works And after he left I moved stuff arond and found hidden plugs that I never knew were in the garage They were hidden bye a piece of scrap drywall I had leanging up aginest a wall
