f 150 lift question | Ford Explorer Forums
f 150 lift question
The exploder
Idaho falls Idaho
1993 sport
so do you guys think that 2 and a half inch bushings will work with this lift becase i had to buy some today for my alinment.......... And i am wondering if i could throw the spacers under there now...... And then of course go back to the alinment shop and have them line it back up......
...you did not use the f150 coil seats??? you will have to get your camber bushings adjusted again but if you put in 2 1/2" already if you go more you will need to add new axle pivot brackets ...;)
I have yet to putt them in! Butt i had to putt in 2.5 camber bushings to get it to line up......will they work for the lift or am i going to have to buy other ones.....
...did you already lift your front end and that is why you had to put in the 2.5* bushings???...you most likely will need to change them and if you did already raise the front, putting in the f150 coil seats you will need the axle pivot brackets.....
