F150 spring question | Ford Explorer Forums
Bonney lake wa
94 Mazda navajo
Hey guys. I'm starting to gather parts for my navajo. I want to do f150 springs, f250 shock mounts and long shocks and some extended factory radius arms with him joints. My question is what f150 springs do i use? Should I use solid axle f150 springs or ttb? Thanks guys. Any input would be appreciated.
Where did you hear about using F150 coils?
I was doing some searching on google and found a guy on trs (sbsrlewis) that runs jd extended radius arms and f150 springs on a b2. After you asked I found his post again and found they are 66-77 f150 stock replacement springs. I know I will have to do some work to the lower mounts and I will probably use f150 buckets also.
