F150 spring seats | Ford Explorer Forums
F150 spring seats
slapthefunkyfou
Farmington, Utah
'91 XL
I think this is what I would like to do first to get some tire clearance. What year of F150 should I be looking for when I get these?
Thanks, Matt
hey i just read a post on this and it said 91-96 F-150 spring seats will work for ya, but you will need 2.75 degree camber corection shim that you can get from napa. installing these your self before you go to the alignment shop will save you some money too.
Blamo, perfect.
Now the 2.75 degree shims MIGHT be the ones you need, they are also the largest correction shim made for the 4x4 TTB.
this truck is a 4x4 correct?
The spring seats when installed on a 2wd truck will require bolts from the 4x4 beams.
Also you could have found this stuff yourself with a simple search :)
