Dallas99XLT5.0
- September 15, 2009
- Dallas,Tx
- '99 XLT
Just purchased a '99 XLT 5.0 with 117,00 in excellent condition. I noticed that the factory rear sub was not working. Pulled the panel and tested for power to the factory amp. The largest wire in the factory plug is a constant 12v. I was reading on this forum and some stated that the amp trigger wire is powered by a 5volt signal not the traditional 12v trigger on a aftermarket head unit. I am assuming that the signal comes from the factory head unit. Tested the 4 other wires with ignition on and off and No voltage. Wires are not pinched. I Removed factory head unit and found no indication that head unit has ever been out or wires and or plugs were disconnected. Checked all fuses on both fuse boxes. Is this a problem with the factory head unit? Thanks!!!
