o2mounty
- October 12, 2006
- snohomish Washington
- 2002 mountaineer
ok, here goes, i am looking to replace the factory amp and sub in my 02 mountaineer. the amp has 5 wires coming in to it, which i assume are power, ground, remote, and left and right channels. i located power, and ground. my question is how do i id the other 3? i tried the test meter routine and didn't get decisive results. i have spent too much time trying to locate a free wiring diagram that has the info i need online. where can i locate that info? Also i've been told that the signal from the hu to the stock amp is already a low level signal, and that i can cut and solder male rca ends to the factory inputs and be able to go straight to the new amp inputs, rather than buy and use a low level line converter. any info, ideas, suggestions, useful anecdotes, etc. would be much appreciated, I'm so close and just want to get bumpin. Thanks
