Factory Subs | Ford Explorer Forums
Factory Subs
TWISTMODE
I've been seeing alot of posts on factory subs. just wondering what vehicles come with factory subs, bottom line does my 91 eb have a factory sub, if so where. thanx
Though you would probably know if you had a sub, you can easily fid out. the sub is loactedo n the back right panel, at the bottom corner, right next to the hatch door. If you have a sub you will see a defienate peice of trim that is separte fromt he others, but is the same color and still flush. You will see a small circle or square of mesh, like speaker grills, in the middle of this peice. If you do not have the sub, there will be a small indentationm or pocket covered by a net to be used as a small cargo holder in the same spot.
Another easy way to tell if you have a factory sub is to turn on you stereo and open the back hatch. Then put your head kind of close to the right panel. If you here distinct bass, you have a sub.
