Wordwoman
- March 6, 2004
- Alsip, IL
- 97 Explorer XLT
Much to our surprise, we recently failed the emission test on our 1997 Ford Explorer. Failure reason: The malfunction indicator light was commanded on Code PO401/EGR Flow Insufficient. (No check engine light had been showing.)
Because we couldn't detect a vacuum on the EGR, we replaced the EGR solenoid. Upon further investigation we found out that no vacuum would be present while revving the engine in the driveway. While driving it with a vacuum hose and gauge attached to the EGR valve, we got a fluctuating reading from 0 - 5. We put a vacuum hose on the EGR valve and sucked on the hose while the engine was running which made the engine almost stall indicating to us that the valve was opening.
Now what? Any suggestions on what might be wrong that would cause me to fail the emission test for insufficient egr flow??
Thank you for any help you might be able to give me. We only have until Saturday when the State of IL suspends both our licenses for failure to pass the emission test!
