V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
I've been using the search feature for about an hour now, but I haven't been able to find anything definite (not that there ever is anything definite )
I have a 1997 v8 5.0 with 4r70w, AWD, and 107k mi that I just purchased. I'm not sure of the maintence history - so I want to do EVERYTHING this weekend:
1) Fuel Filter
2) Engine Oil Change
3) Transmission Filter and Fluid change, pan drop
4) Antifreeze flush and fluid change
5) Transfer case fluid change
6) Front and rear diff fluid change
7) Grease points
8) Clean MAF, TB and IAC
9) Spark plugs and wires
10) Air Filter
11) PCV Valve
Some Questions:
1)How does this list look - anything I should add to it?
2) What filters should I be using for the transmission, would the Pep Boys/Autozone filter be OK, or should I get something from the dealer?
3) For the diffs (The truck has the LS), what gear oil should I use, and which LS additive?
4) T-Case - synthetic or no?
5) Where are the grease points?
Thanks,
Aaron
1) Fuel Filter
7) Grease points
10) Air Filter
11) PCV Valve
Some Questions:
Thanks,
Aaron
