Fitting new radiator | Ford Explorer Forums
Big Bertha
Edinburgh,Scotland
2000 xlt& 1999 model
I'm just about to fit radiator which the fan shroud is connected to basically main radiator.do u guys have any tips and or advice.do I need to bleed anything etc?
Your help would be brill
Pete
i would pull out the bottom rad hose to release the water, and resserve line to the bottle and take the rad cap off to releave the vacum, take the intake pipe off the throttle body and maf so there is clearence, fan shroud is easy to remove, undo the top 2 10mm nuts, lift and push the fan shroud towards the engine to give you clearence as the fan blades wont let you remove it, the undo the nuts on the rad and pull it up
Radiator in
The new radiator is in .there was some oil like lubricant.where is this from and where would I fill bck up to restore level needed.?if you guys could help it would be brill
hi
the cooling rad also acts as cooler for auto box .so you need to check auto box fluid level.
cheers chris
Thanks chris
I checked trans fluid and seems to be plenty .and in great condition.explorer seems to be running brilliant.thanks peter
