sehaare
- October 25, 2008
- Chicagoland, IL
- 98XLT 4WD SOHC,94XLT gone
Hey guys,
I've done several searches and done some of the preliminary troubleshooting and I'm pretty sure at this point I'm going to have to open up the system and replace something and I'm wondering if it is worth buying the tools required to fully troubleshoot this and refill the system after I replace whatever needs replacing?
Here's whats going on
The Vehicle:
1998 Explorer V-6 SOHC with Manual Temperature Control
Symptoms:
The system has had a slow leak for years. I have had to add refrigerant just about every summer and it would blow cold for another season. Added it again this year and it didn't fix the problem.
What I've done so far (after reading other threads suggestions):
With the A/C in Max, I warmed up the engine and verified that the heater hoses to the Fire wall are not hot (no leak-by on the temp control valve)
I fixed my blend door problem years ago by putting a finishing nail through the shaft and have verified that with the heater on, adjusting the temperature dial does change the air temp (I believe this proves that the blend door is moving - but it doesn't prove that it is going fully shut).
With the A/C on Max, the clutch on the compresses is cycling on and off.
At this point all I have is a cheap pressure gauge that comes with the cans of refrigerant and I see the pressure on the Low pressure side cycling as the A/C clutch cycles.
What next:
I've got the ford factory service manual for the vehicle and it has the troubleshooting guide that shows all the expected pressures. So the next step would be to run up to Harbor freight and buy an A/C gauge set and see what pressures I'm actually getting.
My gut feeling is that in addition to the slow leak the years of adding refrigerant with sealant in it has plugged something (possibly the orifice).
I did a refrigerant conversion (R-12 to 134) on another car years ago at a shop that had the A/C equipment required to recover and draw a vacuum on the system so I know a little bit about opening up the system, but no longer have access to that equipment. So at this point I'm believe that I'm looking at having to buy the A/C guage set, a vacuum pump, a new reciever/drier, new refrigerant and oil before I even buy the new part plus my labor.
Would I be better off just paying someone else since I'd have to go out and buy the A/C tools
Sorry this is so long, but I hate when someone post and only gives half of the story.
Thanks
Steve
The Vehicle:
Symptoms:
What next:
Thanks
Steve
