Ahorvat46
- February 27, 2017
- Lexington, Kentucky
- 2004, 4.0 AWD
I bought a used 2004 Mercury Mountaineer 4.0 AWD, at the time I didn't realize it was so common to remove the front driveshaft on these. A couple months later I found out the AWD Mountaineer I had just bought is RWD. The front drive shaft is missing. At the time, when i bought it, the car did not have 4 matching tires. I then replaced all four tires with new matching ones and replaced all four wheel bearings. Over the next few days I drove the car from Kentucky to California and back so it runs quite well. It still sucks that I do not have AWD, I suspect the previous owner removed the front drive shaft because all four tires did not match, this could be an easy fix, However, I am afraid if i put a new driveshaft in I will find out the viscous coupling is bad and I need a new transfer case or the front driveshaft is bad. Does anyone have experience fixing this problem? I am driving to Big Bend National Park in Texas next week and would really like AWD. Please help, thanks.
