dreamr
- October 5, 2003
- Lynnwood WA
- 99 XL / 4x4 / 4.0 ohv
Ok I know it is the second thread with this issue from me and it is a common enough question at that. But please read on a bit. If you would like to visit the other thread here is the link.
http://www.explorerforum.com/forums/showthread.php?t=128017
The original thread was oriented more to the locker issues which have been resolved and I felt may have been related. Now both I and the guys at Randy's are trying to figure the last oddity out. Hence this post. Please note I have never had any 4x4 issues, and it was operated in 4 lo 2 days prior to regearing.
On friday I had the 3.73 gears swapped for 4.56's. The install was good and the wear pattern on them that I saw today was perfect
Well at least according to the pictures in the book
A few miles from the shop my lighted rocker switch (brown Wire Mod) indicating the control track system completely blinked out. Odd I thought it usually dims way way down, but not out. I look back to my dash and see the notorious flashing 4 lo and 4hi lights. 6 flashes per cycle. I attempted to shift into 4x in the next parking lot and got no response form the vehicle in either range. Later that night the battery was unplugged for a bit and everything was working normally again. Including shift to 4 low. I went for a drive and the lights started kicking out my control track. Tested in a parking lot I found that I was able to shift into 4hi and it was really in4 hi. 4 low would not engage, and the auto setting was only functioning as a 2wd when spinning the tires in gravel. I should also note that upon startup and for the first say ten miles auto functions normally then out and blinking lights.
There was also one odd test where it shifted into 2? low
My first thought was what did they forget to plug in?????
I inspected everything several times, I had a buddy inspect everything, Randy's R&P examined everything. It's all plugged in appropriately. Hmmm????
Searching on the internet provided me with three potential candidates for error.
Shift Motor
Hall-Effect Sensors
T-case nedds a flush and fill
I figure I will go ahead and pull the shift motor and sensors for cleaning, but I just don't buy the coincidence. Why would it just happen to go out within minutes of regearing.
That leaves me with a question to those more knowledgeable about the ford explorer than me or the guys at Randy's. I want it fixed, and they would really love me to answer the question for them as well. I was the first late model second gen explorer they have dropped gears that low in. If another comes their way, they want to be able to offer more help than they could with me. Which is commendable I suppose, but doesn't help me right now. LOL
Anyway here is my poorly phrased question.
Could these lights and the disabling of auto be the result of a very confused computer due to the lower ratio?
I believe that on the earlier explorer's there was a VSS in the T-case which monitored a few things in addition to MPH. Often times this is responsible for concerns when regearing. On the newer x's with control track I believe there are two speed sensors 1 for each driveshaft that monitor their rotating speed. Could it be that these sensors are just utterly baffled by the 30% increase in driveline speed? And as a safety measure they are cutting off auto mode and denying access to 4 low.
On these control trac t-cases the shift motor only shifts to low as high is technically engaged by the computer regulated clutches. Therefore when the switch is flipped the already locked in front end activates, but the computer does not feel up to the task of regulating the auto system with these new ratio's.
Does any of this make sense, or am I just barking up the proverbial wrong tree while my shift motor sits there begging for a rebuild?
Shift Motor
Hall-Effect Sensors
