John G
- October 28, 2002
- Milford, CT
- 93 Eddie Bauer
My volt meter doe sthe mambo along with all of my lights flickering in sync with it on my 93 EB. After around 10 -15 minutes it settles down to almost normal. It appears that after the alternator charges the battery for a while it stops flickering. I was told to check the ground. If the ground was bad then wouldn't it continue to flicker even after 10-15 minutes? Could it be the battery? It seems to work fine. All the lights are nice and bright. They just flicker like crazy. Or maybe the alternator. Is there anyway to diagnose an alternator to pinpoint the problem without just replacing parts that might not be defective?
