FML!: Is there supposed to be a hole there? | Ford Explorer Forums
Roadfury
Langley, BC
91 XLT
On my D35 on the front of my exploder.... I have no idea how it hasn't seized up from my past 2 stave excursions.....
How did it happen and how do i make sure it doesn't happen again when i replace the diff?
Short answer, No.. that thread above explains it all. Time to find a spare beam...
~Mark
So I'm guessing adjust bump stops? That sounds like pretty much all I can do unless I want to spend a piss load of money on a mcneil? setup
You don't need a mcneil cut/turned set. Just get a better front lift kit. Duff and others don't have that issue.
The cheapest fix like you said is to adjust your bump stop at least on that side.
~Mark
