Fog lamp relay question! | Ford Explorer Forums
Jamskater112
Indiana
2001 Sport Trac
Hey guys, first post here..I've been around the forums for a while, just haven't ran into any problems, but now I have :/
I read up about being able to have the fog lights on along with the high beams...I saw that you had to pull a relay and break one of the prongs off and then they would work with the highs. I pulled the relay, broke the correct prong, and now I have no fog lights at all.
The led is not turning on on the button, I have no fogs in high or low beam. So what should I do? Just get another Relay? It's a 2001 Sport Trac Job 1. Thanks guys!
Just put in a new relay, the fogs will work as normal.
You may have broken off the wrong prong however. And, I think there's a wiring mod you can do at the switch to have the fogs on.
Well could I switch the A and B relay? Or would I have to just buy another? That was another question I had! I believe the A was the Fog Isolation Relay, and B was the Fog Relay...
First off: Welcome to the forums!
Secondly: Use the search button, it's your friend here
I've searched...a lot. I've been around here for a while, just never posted anything! Thanks for the welcome though!
