thehof2012
- November 4, 2021
- Orange City
- 2010Ford Explorer ST
Hi all!
My Sport Trac is having some weird issues with going into reverse and sometimes into drive. I've found the issue to be most present when the vehicle is cold at start up.
I go from P to R, give some gas, and nothing. RPM's drop down, I can hear it go into R (no loud clunk or anything) and I'm on my way. Every now and again when I pull to a stop sign in D and give it some gas, same thing happens.
I brought the truck to a local shop, they checked tranny fluid levels and it is OK, where it needs to be. Didn't smell burnt fluid either.
OK, well the issue still persists. I have a new filter and intend to change that and the fluid in the pan. Wondering if anyone can suggest where they think this issue is coming from? Should I replace the solenoid pack when I'm in there? Should I replace the reverse servo? (I heard the reverse servo also runs low?)
Also -- since I still have reverse and all forward gears, just "sometimes" happens, does this mean my bands internally aren't broken (yet)?
Trying to figure out where to start and what I should get on order, I really don't want to open this up twice if I can help it!
