Fog Lights Stopped working (again) | Ford Explorer Forums
93Blue2door
93 Sport
Hey I had taken my explorer in to get the grill and left front fog light replaced due to ice flyng against it and breaking them. Anyhow the body shop fixed the left foglight and it worked but the connector on the right fog light was corroded.
So today I went in there and cleaned it all out and connected it up and got it working again and connected it back up. It smoked a little so I made sure my fingerprints were cleaned off of it. I thought maybe the slight whisps of smoke was coming from the gumout on the insulation but just to be sure I pulled out the left fog light. Everything appeared the same and I put it back in. When I went to turn them back on again both were out. I looked in the fuse box and I couldn't find the fuse for them. The owners manual wouldn't say. Could someone give me a solution or two. If it's not the fuse what else could it be?
Ok ignore this. I found the small 20 amp fuse in the Distribution box under the hood. The fuse for the tow lights was gone too. So I replaced them.
What happened I think when I put the lights back in their cases is the rubber backing had gone missing so I wrapped everything in electrical tape. Then put them back. No more short. I just didn't realize the fuses for the fog lights would be under the hood instead of the dash.
