Old trick that worked for us on our yellowed '87-93 Mustang eyes was a little bit of anti freeze swished around... No guarantees though. If it is water moisture, make sure your vents are clear to let air in.
I'll give them a shot when it warms up a little.
Pretty sure that's all that's holding the corners in, 2 screws. But if they've never been removed before they may take a little work. But they should just pull straight out. Try and ease them side to side a little, just becareful not to break the clips.Then remove the Parking Lamp Assembly and finally have access to remove the Headlight Assembly. But I'm stuck on the Parking Lamp thing.
On the CD, it states to "remove the screws" and it points to the 2 top exposed ones. That was straightforward. But on the next step, it just says "Remove the parking lamp assembly." In the picture, it acts as though you can just pull it straight out. Unfortunately, I can't.![]()
