Folding down AND tumbling PIU rear seats | Ford Explorer Forums
atikovi
Mclean VA
2015 PIU
I haven't seen this mentioned before, but as most have figured out, the rear seat backs only fold down, but then won't tumble forward like on civilian models. They are fastened down but they do have the tumble feature built in. To tumble them, remove this bolt at the side,
and these two nuts from the back,
Now the seat will tumble forward.
It's spring loaded to stay in position, although I'm not sure how well it would while driving. This is on a 2015 and I assume it works the same way on the right seat too.
Does it lock back down or just stay with the springs?
Right next to that first pic with the bolt I have a weld there.
Did the weld need to be ground down?
I am still working my way back. Haven't gotten there yet!
An interesting find, but makes me ask? I don't see how this gives a flat floor or more usable space...why would this be advantageous?
Also...in the event of a collision, would the rear seat still be well secured to the floor without the hardware Ford used? My assumption is that Ford bolted it in for a reason. Glad for everyone's thoughts..
It's not bolted down on civilian models so who knows. It's not like you will be driving around like that for very long.
No, it's not welded to the floor.
Ford more than likely bolted it in just in case you have rowdy "passengers" in the back so that they don't break the seats.
Hmmmm! Might be good to keep it as is if you have kids then! I wonder if they still have the chain in the back for the handcuffs?
Thanks for the reply Bud!
The only reason will be to flip it one time for me would be for first time really good cleaning then I'll put it back with the bolts.
On 'civilian' models the seat is latched and locked to a floor anchor when in its regular position. Without that, it likely wouldn't stay in position in a crash, similar to having it unbolted.
Thanks, this helps a lot. I bought cloth rear seats from a junk and have yet to look up how to remove the PIU seats.
Isn't this a great forum to get the answers you need?
So many helpful people (like Peter) that give you outstanding advice!
Reviving an older thread here. I'm in the middle of replacing the rear seats with civilian ones and it looks like all of the bare stampings in the last picture of the original post have to be removed?
You talking about the second row below the seats? The stamped metal pieces are attached to the rear X-brace. The xbrace doesn’t have to be removed but the pieces forward of it that reach below the second row will need to be removed. Do you have the anchor points? The pieces the seats mount to in the second row.
Yes the second row seats. I have the anchor points and all necessary bolts and nuts. It looked like they would have to be removed because they interfere with the tubular anchor points. Thanks for the info.
When I removed the nuts the seat tumbled forward but it was then ONLY connected to the floor by the front bolts. I was able to tumble the seat regardless of folding them so I had to put the nuts back in place as during an accident the seats would tumble forward and injure anyone sitting in the 2nd row. It was a nice time to clean out under the seat as it seems to be the only way to get under the seats.
