Greg_DonWindsor
- February 25, 2007
- Calgary, Alberta
- 2008 Limited V8 4x4
And your bulbs fit in the sockets of the foglight housing fine?
If yes, (Im pretty sure this is what I did on my Explorer, if not, ive done it on other installs) I would just cut the connector off both the explorers stock connector, find out what one is positive, and what one is negative, and snip the ballast connector tip off and match the wires like that. I would solder, electrical tape and heat shrink them just to protect from moisture.
I thought about that, but that means every time a bulb burns out I'll need to clip the wires and solder in the new bulb every time. Less than ideal.
