Ford Explorer 2000 4.0 SOHC ??????? | Ford Explorer Forums
tipton8991
Ohio
Ok, Thought maybe you all could help. I'm not much on diagrams and fairly good with my way around a car or etc.
Problem
The Oil pressure switch which is located on driverside of engine of course looking stright at the front of it. ( located just above oil pan on block) and attched green and white wire. I need to figure out what harness this travels to or through. The guys that pulled my engine some how pulled it from it's location.
Let me repeat, wire attached at the sensor switch, need to locate hook up for opposite end.
Thanks
Steven
You would think that someone might take the time and go outside and pop there hood.This would be very helpful and I sure would be thankful.
Steve
im headed out to look at my 97 ford X to see were mine goes to :-) and will post when i find it but i wish i had seen this post earlier when i didnt need a flashlight lol but in will post back
my wire is green with a white stripe and it goes to the square bolted connector on the drivers side near the back of the engion... if im not mistaken it is a 10mm bolt that pulls the connection together and also separates it.. your wire colors may be different but that's were it ends up at in that bolted connection..
Thank you both.
Will look into it after work today.
Will let you know what I find, thanks again for taking the time to look and finding that other post.
Update, Still have not fixed this problem yet, I check that plug you was talking about and didnt located any part of the green/white wire. Going to do some more looking tommrrow. Birthday yesterday big 40 and of course got a hernia in my belly button to deal with now..lol old age I guess.
I find it or fix it I will update and others have a picture or anything, feel free to jump in.
