ford explorer trans problem please help me | Ford Explorer Forums
balston
ford explorer
when i drive i feel my explorer go back and forward . it's a shift problem i thing on 4th gear. most common when 40 to 50 miles. if i change to 3rd manual the problem dessapear. but when put on drive again the problem start. if i drive on a highway up to 80 miles or more the problem dessapear.
its most common on 40 to 50 miles, an extrange movemet back and forward.
i'm new here any help i will appreciate.
Hi Balston,
Your problem is very common (mine has a similar problem). The short answer to your question is: no one knows 100% answer.
This thread link has some help to determine if solenoid or servo MIGHT be the problem.
http://www.explorerforum.com/forums/showthread.php?t=341593
Other useful links:
SolenoidBlock replacement http://www.explorerforum.com/forums/showthread.php?t=164055
ServoBore info http://www.explorerforum.com/forums/showthread.php?t=262491
My rig still drives, even though it is "clunky" when shifting. My current plan is to drive it until it breaks and then go from there :-)
Some people have very good luck with just changing transmission fluid and filters (not flushing, just changing).
I hope these links help you. I recommend searching this forum and reading ALOT of threads. There is alot of good information that will help you decide what to do.
