FPR 90 Degree replacement inlet outlet | Ford Explorer Forums
JxRock
Reno, Nevada
1991 Ford Expl. 4x4 XLT
This is my first post and I have an issue I hope first of all that I am posting this is the correct area. I have a 91 Ford Explorer v6 4l with the old style push on style fuel line from the FPR. The 90 degree push on part snapped on me and I need to replace it. The FPR is still in great working condition. However I am having a hell of a time finding the replacement push on clip and fuel line. Any suggestions on how to replace that fuel line and any guided procedure would be greatly appreciated. Thanks.:us::exp:
Ford has them. i can't find the part number. You have to buy the whole fuel line up to the quick connect.
Those things rarely fail. I would go to a junk yard and pull one off. you will need the plastic fuel line tool Autozone has them for about $3 for a small set. There is a different size for fuel and return line. I can't remember what size wrench you need to remove it from the fuel rail. I think it's 13mm.
you could probably get both from the yard for about $5-10.
You can also switch your FPR to the new style (non push lock) that came on the 92-94 (don't know if its on anything newer).. I know a few people on here have done that. .much easier to find lines and even FPR for the next time you have to replace it.
~Mark
